Another N54 335i DocRace 6266 by ZNM
Nov 13, 2016
27
17
Pompton Lakes, NJ
Quick Breakdown of the build.
https://www.znmauto.com/single-post/2017/07/11/Ashwins-08-BMW-335i-ST-DocRace-PT6266
  • DocRace Single Turbo Kit PT6266
  • Spec Stage 2 Clutch w/Spec SMFW
  • MMP PI
  • Transmission Rebuild
  • 335is Motor Mounts
  • Transmission Mounts
  • Exhaust Valve Seals Replaced
  • Fuel It! Stage 2 LPFP
  • New OEM Index 12 Injectors
  • New Tensioner Assembly & Idler Pulleys
  • New Radiator
  • New Water Hoses
  • Valve Cover Gasket
  • Engine Oil Pan Gasket
  • Carbon cleaning of Intake Manifold
  • Front Seal Replaced
  • Eldor Ignition Coils
  • NGK 95706 Plugs
