Billet DCT Pan Group Buy
Billet DCT Pan Choice
  • Total voters
    10
lilg1993
Hey everyone! I've been in the middle of a build for my '13 335is for quite some time and its finally all staring to take shape. One of the last things I need to complete everything is a new DCT oil pan, as part of a complete servicing. I had been looking at several options but was a bit hesitant pulling the trigger due to the price (and the amount of $$ I was throwing at everything else on this damn car).
A couple weeks ago I saw a post in the BMW DCT group on fb from the owner of Seems Legit Garage about their new billet DCT pans. I checked them out and they seem pretty sweet and come complete with a Viton pan gasket and stainless hardware. Sent him a message asking if we could do a group buy and he said definitely.
$600 shipped for the "big momma".
$525 shipped for the "mini me".
Includes Viton gasket and stainless hardware.
Quoted 3 weeks turnaround time.
**ALL PANS IN THE GROUP BUY WILL BE ANODIZED BLACK**
So who's in? :D
**GROUP BUY CLOSED 6/22/20**
GROUP BUY LIST (minimum 15 buyers required)
  1. @lilg1993 - Big Momma
  2. @NoQuarter - Big Momma
  3. @Slow335is - Big Momma
  4. [Facebook] Jewel Varughese Stephen - Big Momma
  5. [Facebook] Suraj Chaitan - Mini Me
  6. [Facebook] Anthony Albanese - Big Momma
  7. [Facebook] Jarray Lee - Big Momma
  8. [Facebook] Michael Sardo - Big Momma
  9. [Facebook] John Herrera - Big Momma
  10. [Facebook] Luis Cazarez - Big Momma
  11. [Facebook Jimmy Bacogeorge - Big Momma
  12. [Facebook] Damian Davis - Big Momma
  13. [Facebook] Toman Narusa - Big Momma
  14. [Facebook] German J-r Huerta - Big Momma
  15. [e90post] GORDON.M3 - Big Momma
  16. [e90post] OutoftheBlueM2 - Big Momma
  17. [e90post] B1M3 - Big Momma
**If you have not done so already, please PM me with your email address and to confirm your pan selection**
Our flagship pan, the "Big Momma", is a piece of art built from billet 6061 aluminum. It is CNC'd and designed in the USA. It will also come anodized gold like many of our other products! The prototype shown is just normal bare aluminum. The anodizing helps stop any possible corrosion, and looks amazing!
Overall height of the "Big Momma" is 2.0" compared to the OEM pan which is 1.25" at its deepest point. Holds 3000mL of fluid compared to stock opan which holds 1150mL.
The "Big Momma" pan is full of the following features:
  • Reusable Viton O-Ring gasket. No more leaks or expensive OEM gasket replacements!
  • Proper drain plug with magnet
  • Super-large capacity pan, 2.25" deep, for more capacity and heat capacity
  • Huge cooling fins both inside and out for maximum heat dissipation
  • Large fins inside the pan to act as a pan baffle to reduce aeration during hard braking, acceleration and cornering
  • Threaded boles in the bottom so you can screw in hardware and slide the transmission on the ground without damaging the pan
  • 3 different bosses of proper thickness to tap and thread to suit any ports or temp sensors required
The "Mini-Me" Pan we offer is very close to the same size as the OEM pan, for maximum ground clearance. This is great for small cars with the DCT swap. Still features the Viton O-Ring and instead of colling fins, features a bullnose finish for increased surface area inside and out for increased cooling capacity without decreasing ground clearance. Holds 1500mL of fluids compares to 1150mL in the factory pan, all without going past the 1.25" depth.
Slow335is
I’m in for big momma pan, prefer red or black. I have fully built SSP 1000+ dct trans with mfactory single mass race flywheel.
houtan
Do these come with an extension for the oil pick up or is that not needed? I think I remember a different pan (slonik I think) that cane with an extension.
Same pan in the Z4 for anyone interested. Next I'll get it up in the air and see about room for a deeper pan.
Asbjorn
Seems this product is missing the three outlets for oil cooler and thermostat that the ssp type has.
lilg1993
The description above gives two different sizes for big momma. Is it 2" or 2.25"?
I've noticed that too. I can't say for sure which size it is, but I'm not really worried about .25"...that may be a different story if you are DCT swapped into a completely different car tho
Sounds as if it has outlet ports. But in any case, the oil cooler lines run out the side of the DCT, not the pan
lilg1993
2 or 2.25 may be the difference between keeping the undertray or cutting it away.
Fair point. I have heard of people who run larger DCT pans simply cutting the under tray in the shape of the pan directly underneath it, allowing them to essentially retain the pan everywhere else
Without the pickup extension you may get oil surge. I don't know if its as serious as it would be for an engine pickup but I doubt it would be ideal
lilg1993
Does anybody know where a pickup extension can be purchased? Wonder if it would be worth it...
lilg1993
To anyone interested in getting in on the group buy, please PM me with which size pan you want and your email address. I need to provide the manufacturer with the number of each pan and an email for billing/invoicing.
Comes with Viton gasket and stillness hardware. 3 weeks turnaround time.
Slow335is
Just did
Top
