We are proud to introduce PFS or performance fueling solutions to everyone!
PFS is a dedicated fueling company for the performance aftermarket. We do not do anything else, fueling is our passion, and it’s what we do best. PFS was born due to the lack of fueling solutions that were both well-engineered and cost-effective. We found some products (though well engineered) are at a very steep price point, and while others cost a reasonable amount, they are simply copycat bucketless adapters with little thought given to proper design. We decided high-quality fueling options were needed at prices even budget minded enthusiasts can swallow. Everything PFS creates is functional, offers perfect fitment, and of course, the design is maximized for ease of use.
PFS is bringing a wide range of products to the market for the E9X/E8X platform, as well as many standalone parts that can be used when building custom fuel systems. Every fitting we use in our kits is available to you on its own -from our plastic fittings, billet fittings, corrugated fuel line, crimp clamps, we allow you to purchase all of it if you choose to build your own parts!
We have many more products for other platforms already designed, and in the production, phase to be released at a later date. This includes the VW MK7 MQB engines, BMW S55, Audi RS3, as well as Flex Fuel/Ethanol percentage monitors for a wide variety of platforms.
All of our BMW buckets are 100% Brand new, we do NOT have a core charge, and you do NOT need to send your old pump in. We have invested heavily in up-to-date equipment, including a plastic sonic welder -all buckets are welded together just like the factory does -no pop rivets or glue.
Available now is our full line up of bucketed and bucketless options, running stock or external fuel lines, Port Injection kits, the most complete external fuel filter/FPR solution on the market which combines everything into one small plug and play package, upgraded fuel lines, Walbro 450, and 525 fuel pumps, crimp clamps, push lock hose, tools, etc.
The website is live at PFS WEBSITE
Follow us on social media:
Performance Fueling Solutions
Performance Fueling Solutions, Scottsdale, Arizona. 165 likes. High Performance Fueling you can actually afford!
www.facebook.com
Performance Fueling Solutions (@performancefuelingsolutions) • Instagram photos and videos
1,408 Followers, 543 Following, 221 Posts - See Instagram photos and videos from Performance Fueling Solutions (@performancefuelingsolutions)
www.instagram.com
Here is a short list, pricing, and features of a few of our products.
For Black Friday we will be discounting the entire site an additional 15%. The link in the vendor marketplace!
E9X/E8X Bucketed Upgrade “Stock Series” Drop in replacement (Before Options)
- Single Shot 450 - $499
- Double Shot 450 - $699
- Single Shot 525 - $549 (contact us for details)
- Double Shot 525 – $799 (contact us for details)
All PFS Single Shot Bucketed pumps include the following:
- A complete plug and play solution by simply replacing your stock bucket
- A new E85 compatible Walbro 450 F9000274 pump
- A new Walbro filter
- Flow testing on the PFS test bench prior to shipping
- Two new E85 compatible Walbro 450 F9000274 pumps
- Two new Walbro filters
- Wiring Harness for the secondary pump with Fused power
- Hobbs Switch
- Fuel pump relay
E9X/E8X Double shot Bucketed Upgrade “External Series” (Available in dual-pump only)
- External Dual 450 - $999
- External Dual 525 - $1199 (contact us for details)
All PFS "External Series" Bucketed pumps include the following:
- A complete plug and play solution by simply replacing your factory bucket
- Two New E85 compatible Walbro 450 F9000274 pumps
- Hobbs Switch
- Fuel pump relay
- 3/8 QD fitting on the Passenger side top hat
- -6 Fuel line from Passenger side tank to front of the vehicle
- -6 Fuel line from Driver side tank to front of the vehicle
- PFS 10-micron filter with choice of outlet fittings
- External Fuel Pressure regulator with return line $249.00
- Outlet fitting for the filter
- Return fitting on passenger top hat
E9X/E8X Bucketless Upgrade “Stock Series” Drop in replacement (Before Options)
- Single Shot 450 - $349
- Double Shot 450 - $549
- Single Shot 525 - $399 (contact us for details)
- Double Shot 525 - $599 (contact us for details)
All PFS Single Shot Bucketless pumps include the following:
- A new Walbro filter (Hydra-Mat available in options)
- Two new Walbro filters (Hydra-Mat available in options)
- Hobbs Switch
- Fuel pump relay
E9X/E8X Double Shot Bucketless Upgrade “External Series” replacement (Before Options)
- External Dual 450 - $799
- External Dual 525 - $899 (contact us for details)
All PFS "External Series" Bucketless pumps include the following:
- A complete plug and play solution by simply getting rid of your factory bucket
- Hobbs Switch
- Fuel pump relay
N54/N55/S55 Port Injection kit
Available in 4 configurations with some options as well such as 950Cc Injectors
- Basic Package (DIY) $299
- Stage 1 (RTR)- $599
- Stage 2 (RTR) - $699
- Stage 3 (RTR) - $899
- PFS PI Spacer
- PFS PI Rail
- High-Quality hardware
- 6 Extended bolts for mounting your PFS spacer
- 6 custom PFS gaskets
- 1 -6ORB to -6AN fitting
- 1 -ORB plug
- NO Injectors
- NO LINES
- NO Controller
- PFS PI Spacer
- PFS PI Rail
- 6 Custom PFS gaskets
- 6 Flow Matched US SOURCED "DW" 550CC injectors
- 1 -ORB plug
- Basic line kit from factory line to HPHP feed, and PI using PFS high flow fittings, and -6AN fuel in
- PFS PI Spacer
- PFS PI Rail
- 1 -ORB plug
- Upgraded line kit from the driver side fuel tank to HPHP feed, and PI using PFS high flow fittings, and -6AN fuel in
- Stage 3 RTR kit - $899 (ready to run, except for controller)
- PFS PI Spacer
- PFS PI Rail
- PFS Fuel Pressure regulator
- PFS Return fitting for passenger bucket
- 1 -ORB plug
- Upgraded line kit from the driver side fuel tank to HPHP feed, and PI using PFS high flow fittings, and -6AN fuel, and -6 Return line from the regulator to passenger tank
- All required fittings for installation
