What is your experience with the POD?Thanks, but I already have a POD installed on my car.
I actually had Helix, but sold that before installing to my car. Now I bought that PFS POD from Neg89. I will also install Walbro 535 + inline filter with upgraded fuel lines (remove HPFP filter) when I get the car in the spring (April I think, I'm from Finland). I currently have Walbro 450 which has so far been OK. And I have another ekpm3 with thermal pads, heatsinks and fan ready also.
Other thing was that I was planning to replace the in tank regulator/filter unit as the original has almost 170tkm. Did you use the PR top hat you mentioned earlier? That would still require pressure regulator right?
