Vargas crank hub bolt capture question
Erichale77
827
447
Clearwater, FL
07 E92 coupe
It's a good piece of mind. Here's mine Tony made for me for the ATi dampner. Resized_20190220_123340_1899.jpeg
MoistNapkin
104
89
08 135i
It's to prevent the bolt backing out and losing pressure on the sprocket
I understand it's purpose, older BMW's use a nut instead that owners often locked with wire to prevent backing out.
That's more like it, I feel that design is actually superior. The user can use the crank bolt for maintenance without worrying about loosening that oh so essential bolt.
1,620
Curious if the intersection of those smaller circles to the larger may be stress risers.
Interesting observation. Looks to me that could be a weak point in the design.
I’m also wondering if the functionality of the Vargas crank hub bolt capture can be combined somehow into one piece with the functionality of Ozwerk’s $150 crank seal plate to prevent broken serpentine belts getting sucked into the crankcase...that would be super useful. If not, could both be installed together?
@Chris@VargasTurboTech ?
MoreBoost
361
143
Well obviously the greater contact area you can have between the bolt and the capture, the better you can distribute any forces of the bolt trying to rotate and hopefully the less chance of that happening. At the expense of preventing maintenance where you may want to be rotating the crank by hand but you can bump it with the starter.
MoistNapkin
104
89
08 135i
As mentioned no stress/force is being put on that bolt. The plate is there simply to stop any rotation IF it were to come loose. Which is why you can use just a metal wire on the Crank Nuts of older bmw's. In this case it just appears over engineered which is absolutely not an issue. Chris one post above also describes its purpose as well. I prefer the hand method cranking 10/10, but that's just personal preference on how we work on cars ehh? Cheers!:)
