Chris@VargasTurboTech
Hey Guys happy to announce our latest VTT product solution for the N54 platform.
VTT Cast CNC aluminum N54 valve cover.
We have been working on this for a while, trying to balance cost-effectiveness with good looks and high quality. We believe we have found the solution. This is a cast version of our incredibly popular Billet CNC valve cover. Instead of starting with a billet piece of aluminum, this cover is cast, then it goes through the same machining process as our billet VC. This keeps the cost down and makes for an awesome valve cover that eliminates the factory plastic cover (and its cyclonic PCV system). This allows you to run any of our modular PCV fittings, crankcase breather, vacuum relief, billet banjos, catch can kits, etc.
This truly is the best bang for your buck Valve Cover upgrade on the N54 market. High quality, low price, great looks, no cracking, and unlimited PCV plumbing options makes this a no brainer upgrade!
We offer three color options. Clear Anodize (please keep in mind, this will show casting imperfections as not all surfaces are machined), Black Wrinkle and Red Wrinkle Powder coat (wrinkle finishes will hide all casting imperfections and look the best). There is no charge for powder coating options. We offer custom colors of anodizing, and powder coat at $150 for either.
Valve Cover Details:
IMPORTANT NOTES:
The Cast Aluminum CNC Valve cover is currently available for Pre-Order and we should have 10 Black Wrinkle, and 5 Red Wrinkle in about 2-3 weeks.
A direct link is here: http://performance.vargasturbo.com/ecommerce/index.php?route=product/product&path=65&product_id=138
- Price $649.00
- Cast CNC 6061-T6 Aircraft aluminum construction
- Anodized or powder-coated in a variety of colors (Color Pictures coming shortly)
- Lightweight; 9.0 lbs. (compared to 7.9 lbs for a stock cover - only 1.1 lbs difference)
- Gives the end-user true variety for setting up their Valve Cover and PCV System by utilizing all existing VTT PCV fitting, and breather options
- Lower pricing than other non-modular cast options on the market
IMPORTANT NOTES:
- THE STAINLESS BREATHER WILL NOT FIT ON THE FRONT ORB AS IT WILL NOT CLEAR THE HOOD.
- This cover may or may not fit with your engine cover depending on how you have it set up, and is designed to be run without an engine cover.
- This fits the BMW N54 engine ONLY
